- SCUK is my life
Post
by andyrew » Tue Apr 26, 2016 9:35 pm
Thats just the old lwb body after id finished cuting out the rot
Back to good metal
- SCUK is my life
Post
by andyrew » Thu Apr 28, 2016 3:58 pm
Kja chassis do love to rot. I wonder what stage they skipped that
Makes them rot so bad.
kiwizook
- SCUK Addict
Post
by kiwizook » Fri Apr 29, 2016 4:23 pm
You'll probably find there's holes rusted in the top of the chassis leg when you cut the old supports of. The supports have drain holes in the bottom, which block and rot out the support, but unfortunately often rot a hole straight down too through the chassis leg, so you'll have to plate those too
stevepsj413
- SCUK is my life
Post
by andyrew » Sun May 08, 2016 6:07 pm
Ohh dear. Thats a shame.
Do you have a cheap sandblasters locally? Or source a donor
Swb chassis for repair sections.?
Rabid Rhino
Post
by Rabid Rhino » Tue May 17, 2016 3:54 am
Weekend update ?
- The Boss
Post
by ScottieJ » Tue May 17, 2016 9:43 am
stevepsj413 wrote:
Removed the cab from the chassis and found some big holes in the chassis under the rear of the cab, also the drivers side chassis rail is a bit bent.
Dont know where to go from here, welding I can handle but bent chassis rails?
I would take some measurements to check that it's actually bent, I have seen a few chassis with similar bulges from the forming of the chassis rails in the factory.
the rails and dimensions should be the same as the lwb ones here.
http://www.suzukiclubuk.co.uk/tech-spec ... s-diagrams
stevepsj413
Post
by stevepsj413 » Tue May 17, 2016 2:38 pm
Its deffo bent. Took springs off over weekend. Front nearsides a normal front spring, front offside has a rear spring instead of a front spring, ill put pics up wen i get home of the springs. I thought to do rear up front you had to make brackets to relocate the front spring shackle?
