Evening all.
Re: Evening all.
Post by Tramp » Thu Feb 25, 2016 6:17 pm
Funny really, my SJ has the cylinder on the bottom of the shoes rather than the top
Click Here for Youtube Video
Is your vitara Spanish or Japanese?
Re: Evening all.
Post by dan_2k_uk » Thu Feb 25, 2016 9:08 pm
Welcome. That rear drum can't of been doing a lot. :yuk:
dazvit
Re: Evening all.
Post by dazvit » Thu Feb 25, 2016 10:34 pm
8-) Thanks for the welcome's guys.
Nah Dan it was doing f-all, I took a look at the handbrake cables today and one of the cables wasn't in its location point next to the hand brake lever,so with a bit of fiddling about , it's all working now.
See, we don't have MOT over here and 'some' Locals must drive around in death traps :screwy:
Re: Evening all.
Post by twiss » Sun Feb 28, 2016 7:31 am
fyi i think the cylinders are supposed to be at the top, but at some point have been swapped around. Mine were on the bottom too. Bit stupid to have them on the bottom as it drags the bleed nipples through any mud you go through!
dazvit
Re: Evening all.
Post by dazvit » Mon Feb 29, 2016 2:13 pm
Now all the brakes are working as they should, I thought it would be a good idea to check how bad the rear floor pan behind the rear seats is for rust and um' :| after firing up the grinder :guns: I'm left with this vvv
Re: Evening all.
Post by twiss » Mon Feb 29, 2016 9:31 pm
Nowhere near as bad as my Samurai! :)
robbie1985
Re: Evening all.
Post by robbie1985 » Sun Mar 13, 2016 1:29 pm
Hello and welcome, if the back is that you might wanna check the foot wells behind the seats.
Re: Evening all.
Post by Jordi » Sun Mar 13, 2016 9:42 pm
Looks like you have your work cut out with that.
Don't think previous owner has been too conscious about safety.
dazvit
Re: Evening all.
Post by dazvit » Tue Mar 15, 2016 6:47 pm
robbie1985 wrote:Hello and welcome, if the back is that you might wanna check the foot wells behind the seats.
Cheers Robbie, yeah I removed all seats and carpet and there was some rut, mainly driver side.
All patched up now :thumbup:
Next job is check out the springs and shocks, because it seems to have a bit of a Gangsta Lean to the right :|
Re: Evening all.
Post by twiss » Wed Mar 16, 2016 11:22 pm
Find yourself a fat passenger ;)
