cant find these anywhere...can any one help?
slimady121
Post by slimady121 » Sat Apr 18, 2015 9:08 pm
need a pair of these for a coil conversion
Re: cant find these anywhere...can any one help?
Post by donkeychomp » Sat Apr 18, 2015 9:23 pm
That looks suspiciously like my high steer kit...avoid the total arse who I bought mine from. See the latest few posts on the no dosh lj revamp.
Post by andyrew » Sun Apr 19, 2015 12:03 pm
It's a high steer kit.
I believe rob storr is the only guy making these
Regularly.
I've personally always had great service from Rob
And I would highly recommend him.
But there are a few complaints by other previous customers.
chrisj410
Post by chrisj410 » Sun Apr 19, 2015 12:41 pm
If donkeychomp is talking about rob storr I'm another vote for avoid him, I could understand the poor service if the products were good
d_r_1989
Post by d_r_1989 » Sun Apr 19, 2015 9:19 pm
You might be better of using the mercedes ones.
slimady121
Post by slimady121 » Sun Apr 19, 2015 9:28 pm
i cant find them anywhere
Post by andyrew » Sun Apr 19, 2015 9:32 pm
Do you mean the steering
Arm or a you just looking for ball joints?
Post by ScottieJ » Sun Apr 19, 2015 10:03 pm
d_r_1989 wrote:You might be better of using the mercedes ones.
I would rather run a properly built hi-steer any day than bodging merc arms on, they have the wrong taper for the Suzuki rod ends and don't really bolt on well, you have to oval one of the holes and then they just bolt to the caliper carrier. They don't tie into the existing steering like the proper kits. I would rather not add additional stresses to my brake mounts by attaching the steering to it.
Steering and brakes are two things I will not skimp on.
I've never had an issue with my full floater kit from him, most of his stuff is well made and strong.
I thought you had no issues in the end Alex....when he eventually sent you the steering links rather than ladamans shafts :lol:
However there is an issue with all high steer kits...they ruin the Ackerman angle, only way to keep the Ackerman angle is to do a half high steer, keeping the original tie rod.
Post by donkeychomp » Sun Apr 19, 2015 10:58 pm
I still had issues with him...I had to source a load of bolts and such to get the thing to fit. And the message 'you have a big mouth you work out how to fit it' still gets on my pecs..
