Hi Guys, could anyone point me in the right direction please? The little sj 410 runs a treat but the idle speed keeps changing, one day it will be correct the next racing on a little. I've checked the return springs and the throttle appears not to be sticking, alittle bit of duck oil for good measure. At a bit of a loss, somebody the other day mentioned the needle may be sticking,, Needle??? not sure what this is.
Look forward to your comments.
Many Thanks.
Andy.
Changing idle speed!!
Re: Changing idle speed!!
Are the revs constant?
Or are they fluctuating while running?
Have you tried redx?
Hi thanks for replying. The revs are constant either at a low or higher idle speed.
Andy.
Andy.
