sami axles
suzukisteve
sami axles
Post by suzukisteve » Fri Jan 10, 2014 9:06 am
morning lads.
bit of a question regarding sami axles.
if I were to put a set on my 410 how would the gearing be? and what do I have to modify to make em fit?
I have something in the pipeline and may be able to get a set ;)
pickle power!
Re: sami axles
Post by ScottieJ » Fri Jan 10, 2014 10:53 am
suzukisteve wrote:morning lads.
Gearing will suck if you still have a 970cc, would be a bit better with 413 3.9:1 diffs but ideally with the larger tyres you'll want to get two front 4.6:1 vitara diffs to fit the r&p intot he samurai diffs
Ladaman
Re: sami axles
Post by Ladaman » Fri Jan 10, 2014 12:44 pm
I'm pretty sure you need to move the position of the spring perches as the springs are in a different position.
Re: sami axles
Post by ScottieJ » Fri Jan 10, 2014 12:53 pm
Ladaman wrote:I'm pretty sure you need to move the position of the spring perches as the springs are in a different position.
Yes 40mm inwards each if I remember correctly
suzukisteve
Re: sami axles
Post by suzukisteve » Fri Jan 10, 2014 2:19 pm
just a thought but suddenly remembered what im getting hold of! scottie, have a look at that link I pm'ed you. then think where im going wrong here...
pickle power!
Re: sami axles
Post by ScottieJ » Fri Jan 10, 2014 4:54 pm
haha I get you! I might have a spare samurai rear axle, or all the parts you'll need to build one :thumbup:
