Spark plugs...
- turbo-tom
Spark plugs...
Bit of a weird one this.. its relating to my coursework the question is:
If a spark plug has the earth electrode corroded away will it still spark?
my answer id say that it wont? because it has nothing to ground out to and produce a spark etc
am i right? or am i wrong? cant seam to find an answer :/
cheers tom!
cheers tom!
- Edweird
Re: Spark plugs...
Sounds right to me.turbo-tom wrote:Bit of a weird one this.. its relating to my coursework the question is:
cheers tom!
- turbo-tom
Re: Spark plugs...
Thats what I thought , been trawling the web and reading in books for ages for not to get an answer.
Cheers Ed
Cheers Ed
- Edweird
Re: Spark plugs...
The only possibility is that a spark might jump from the electrode and ground through the cylinder head, but I think that's extremely unlikely due to the compression, as it is harder for electricity to pass through gasses when they are at higher pressure; hence why low pressure weather systems bring rain and storms.
- turbo-tom
Re: Spark plugs...
hmm I guess that is possible but like you say very unlikely... cheers for that though!
can't wait to finish the course and get out in the fields repairing machinery
Re: Spark plugs...
Yeah. Those bloody land rovers. Always breaking downturbo-tom wrote:hmm I guess that is possible but like you say very unlikely... cheers for that though!
- Ladaman
- Suzuki Guru
Re: Spark plugs...
I'd think it would.
Surely the spark would just jump to the threaded part which is earthed to the cylinder head.
Do you have an old plug you can grind the earth electrode off, and then do an experiment?
Re: Spark plugs...
I'd have thought it would track down the insulation and spark across to the threaded section, it only uses the cathod as it's the path of least resistance - when your plug gets wet or it gets carbon deposits on it it does this anyway. Although as the spark is recessed it won't ignite the fuel properly or at the right time, also it will be a different sort of spark as it's having to work harder, instead of a short fat blue spark it will be a longer thinner lighter coloured spark,
Re: Spark plugs...
I would try this but first I would adjust the gap and see how the spark changes across the bigger gapLadaman wrote:Do you have an old plug you can grind the earth electrode off, and then do an experiment?
- turbo-tom
Re: Spark plugs...
That's what I was thinking first of all.. and I thought i did i was just going to test it and have a look but i couldnt find any laying around in the garage, and to see what would happen!Ladaman wrote:I'd think it would.
hmm yeah so basically its going to explode the fuel rather then ignite it properly making the engine run hotter...Tramp wrote:I'd have thought it would track down the insulation and spark across to the threaded section, it only uses the cathod as it's the path of least resistance - when your plug gets wet or it gets carbon deposits on it it does this anyway. Although as the spark is recessed it won't ignite the fuel properly or at the right time, also it will be a different sort of spark as it's having to work harder, instead of a short fat blue spark it will be a longer thinner lighter coloured spark,
Anyway cheers Chaps! ive all taken your good info in and ill report back just out of interest when I get the assessment back!
