Quick question about front crankshaft seal..
Jay18
Post by Jay18 » Wed Oct 16, 2013 4:42 pm
Basis clay is the front crankshaft seal behind the oil pump or is it in the oil pump housing? Need to so the oil seals and could do with a bit of advice to help me a bit..
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Re: Quick question about front crankshaft seal..
Post by ScottieJ » Wed Oct 16, 2013 5:01 pm
it's at the front of the crank, behind the lower timing belt pulley
Jay18
Post by Jay18 » Wed Oct 16, 2013 5:49 pm
Is it easy so change? How would I go about getting the old one out and new one in?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
suzukisteve
Post by suzukisteve » Wed Oct 16, 2013 8:19 pm
im guessing here, but mark up and remove the pulley first then you may be able to use a small pick to, well, pick tge old seal out. once out remove any dirt and crud out and put the new one in.
pickle power!
Post by turbo-tom » Wed Oct 16, 2013 8:28 pm
you have got the cambelt aswell behind if is only if its leaking id change it but if it isnt i wouldnt bother unless your doing a full engine rebuild.
Jay18
Post by Jay18 » Wed Oct 16, 2013 9:42 pm
It's definitely in need of a change cause it's pissing out oil lol, I'm hoping to get it done this weekend, I've had someone say they have a 410 engine that he's taking out and it's had the head skimmed and a new gasket so if I can get that then I'll put the oil seals on the doner engine and use that, all depends on how much he wants for it and how soon he can get it out of his sj..
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
