transfer box
screeminsj
transfer box
Post by screeminsj » Sat Sep 28, 2013 7:17 pm
Hi does anyone know if you can fit a jimny transfer box in to a 410, as my 410 is noisy with wobbley bearings and wot the gear ratios are? thanks steve
Re: transfer box
Post by Tramp » Sat Sep 28, 2013 7:25 pm
It's not a direct swap and I don't know why you would want to? Jimny boxes are chain drive, these chains go slack and start slipping, the SJ t-box is much more robust item. Whip the box out and change the rough bearing, it's not a difficult job
Re: transfer box
Post by Jordi » Sat Sep 28, 2013 7:28 pm
Might as well just get the bearings done. Jimny owners generally swap to SJ transfer boxes are they are so much stronger.
Not sure about the actual mounts but i know the speedo drive is different.
screeminsj
Re: transfer box
Post by screeminsj » Sat Sep 28, 2013 7:30 pm
that's why there so much cheaper then. thanks for advise
