engine mount
engine mount
hello people I fitted my vitara engine in sj410 today to see where the mounts would go but looks lyk engine would sit lower that the std chassie mount any one got any pics thanks
Re: engine mount
Tim has just done a similar swap. He got a set of 413 mounts cut out of an old chassis and welded them straight in.
I do have a set up for grabs if required.
Re: engine mount
ahh with the vit engine I got the mounts so would I use them n when I put my engine in, it seems to sit quite a lot lower than the std chassie mount is that right
Re: engine mount
No. It should sit above the old mounts.
Re: engine mount
will have a propa look 2morrow will align the engine up straight and look from there if a get the 413 chass mounts what engine mounds do I use thanks jordi
Re: engine mount
I used all the SJ engine mounts including some of the cast mounts off the block.
Re: engine mount
Ok thanks jordie , will get back to u about the chass mounts , quick question do u no the best angle or possition to have this engine sittin
Re: engine mount
Think is sits fairly level. Easiest way would be to sit gearbox on its mount and line it up from there.
- timwilks13
- SCUK Website Padawan
Re: engine mount
If you are going from a 410 to vit then I would cut out your old mounts and weld in the 413 ones, I think an advantage of this is that you won't have to drill out the left mount like you do on the 413, you can just weld it straight in the right place.
Re: engine mount
yer got the gearbox mount on and engine chocked up ready for fitting mounts, thanks tim think al do that , any pics ? thanks
