which clutch kit
suzukisteve
which clutch kit
Post by suzukisteve » Mon Aug 19, 2013 10:55 am
morning everyone.
I'm gonna be changing my clutch in the not to distant future. the problem im having is that im running my santana f10a engine from my old 89 plate sj.
im gonna be swapping to a 5 speed from andyrew. so my question is do I got for the clutch for the 89 plate engine or the box from andy?
pickle power!
Re: which clutch kit
Post by Jordi » Mon Aug 19, 2013 11:51 am
New one
Post by turbo-tom » Mon Aug 19, 2013 12:36 pm
new clutch whilst your down there. id always change a clutch if im splitting the engine and gearbox! just makes more sence otherwise 300miles or so later you might be taking it all apart again!
suzukisteve
Post by suzukisteve » Mon Aug 19, 2013 12:56 pm
no I mean there is a choice on the new ones. Basically if I use the reg for my engine the part number is different to the sj im using now.
for example if I use the g reg its adk83017
the c reg is adk83008
but because my g reg engine is in the c reg I dunno what clutch to use without stripping it all down.
clear as mud lol
pickle power!
Post by ScottieJ » Mon Aug 19, 2013 1:01 pm
Use your old reg, however it shouldn't matter as i'm 99% sure all 410s should use the same clutch :er:
Boyes
Post by Boyes » Mon Aug 19, 2013 1:05 pm
Will depend on which flywheel you use, as there is an early and a later type :thumbup:
Boyes
Post by Boyes » Mon Aug 19, 2013 1:07 pm
ScottieJ wrote:Use your old reg, however it shouldn't matter as i'm 99% sure all 410s should use the same clutch :er:
My Santana 5 speed had a different clutch basket? Can't remember the name gone brain dead, to the 4 Speed VBJA Van I swapped it into from what I remember it was the clutch basket locating dowels that were different and I just used the best bearing/clutch!
Which is similar to my 106, later models have a different flywheel but the clutch itself & release bearing is all the same.
suzukisteve
Post by suzukisteve » Mon Aug 19, 2013 1:09 pm
ok cool I'll double check it all. in fact I may order both and just chuck the one I don't use back to blueprint
pickle power!
Post by ScottieJ » Mon Aug 19, 2013 1:30 pm
Ah my bad, I know that the actual clutch plates are all the same.
Either way Steve just use the reg that the original engine came out of, unless you swapped the flywheel from the new SJ onto it, then use the C reg plate
suzukisteve
Post by suzukisteve » Mon Aug 19, 2013 1:33 pm
coolies! I don't think ill have to swap the flywheel for the 5 speed, so jobs a good un so to speak
pickle power!
