oil everywhere!
timwilks13
SCUK Website Padawan
oil everywhere!
Post by timwilks13 » Sun Aug 11, 2013 8:38 pm
did an oil change today and used that engine oil cleaner stuff first, went for a little drive afterwards and when I got home there was oil everywhere, it has dripped down onto the front prop shaft and been flung everywhere so I have no idea what's leaking, pretty sure its not the sump though.
I think I have a Spanish engine, can anyone confirm if the Spanish and Jap builds use the same gaskets as I only have a number plate for a Jap build to order an entire top half gasket set, as I'm thinking I might just change em all to fix this mystery leak!
windsor
Re: oil everywhere!
Post by windsor » Sun Aug 11, 2013 8:52 pm
Have you swaped for fully sinthetic oil
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
Re: oil everywhere!
Post by Jordi » Sun Aug 11, 2013 8:54 pm
Same gaskets.
Pressure wash the engine bay then run it and see if you can spot any leaks.
Re: oil everywhere!
Post by andyrew » Sun Aug 11, 2013 10:42 pm
Its definitely a Spanish engine tim. But I don't know the reg.
Sounds strange. Have you gone for a thinner oil?
Re: oil everywhere!
Post by Jordi » Mon Aug 12, 2013 10:17 am
I can get a spanish reg for you, or you can use Dans, sure he wouldn't mind.
timwilks13
Re: oil everywhere!
Post by timwilks13 » Mon Aug 12, 2013 11:31 am
I just used 10 40 as I usually do, though I have just read that on older engines the build up of crap in old oil can plug small leaks, so when engine flush cleans all that crap out you can find a world of new leaks! ill go with the pressure washer plan tonight and see what the crack is, and I have also booked Thursday off work now to have a day to hopefully get this fixed for Friday!
by Dan jordi do you mean Dan2uk? if so ill pm and ask him.
Re: oil everywhere!
Post by ScottieJ » Mon Aug 12, 2013 12:01 pm
timwilks13 wrote:I just used 10 40 as I usually do, though I have just read that on older engines the build up of crap in old oil can plug small leaks, so when engine flush cleans all that crap out you can find a world of new leaks!
This is most likely the cause.
Doesn't matter if it's spanish or Jap all the gaskets and seals will be the same :thumbup:
Re: oil everywhere!
Post by Jordi » Mon Aug 12, 2013 12:23 pm
Yeah Dan2ks is a spanish model.
timwilks13
Re: oil everywhere!
Post by timwilks13 » Mon Aug 12, 2013 2:38 pm
did a compression test and got 7.5 bar across all 4 so can I rule out head gasket? only thing with that is when I rev it there is a healthy amount of black smoke coming from the exhaust?!
I'm still going to pressure wash it to see but trying to narrow down the possibilities whilst at work.
Re: oil everywhere!
Post by ScottieJ » Mon Aug 12, 2013 2:52 pm
Black smoke usually indicates that its running super rich so check the choke isn't stuck on and that the air filter is clean/ not blocked etc.
