wont start
wont start
Re: wont start
Squirt a little WD-40 or easy start down the intake, choke on & a little throttle (Not too much that it bogs down) my 410 struggled to start from cold.
Re: wont start
- Edweird
Re: wont start
Is it popping and farting at all or is it just turning over?
Re: wont start
Pour some petrol into your air intake on your carb like a pop bottle cap full works a treat on carb lumpd av fired up no end of cars and bikes buy doing that
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
cd players
99% rust free
alloys
bukets
Re: wont start
If its got spark at each plug then there's only two other things that it can really be.
A fuel issue, pull the fuel pipe off the carb and turn it over to see if fuel squirts out.
If you have fuel and it still doesn't start then it is probably an timing issue.
Re: wont start
All good advice but don't discard the fact that you may have a spark with the plug outside of the cylinders but they may be breaking down when under pressure. I've just had a very embarressing lesson with my sit on mower - it conked out for no obvious reason, I checked the plug for sparking, checked the key which holds the flywheel in place incase the timing was incorrect and removed the cylinder head to inspect the valves - all okay.
Took it to an expert who put a new plug in and away it went - all due to the plug braking down under pressure, and me an ex- aero engine technician!
Re: wont start
Have you had the leads off? If yes are they on the right order?
