newbie question im afraid
timwilks13
SCUK Website Padawan
Post by timwilks13 » Fri Aug 09, 2013 7:21 pm
how on earth do i get the front calipers off? i have removed the two big bolts that hold the whole assembley on, then used water pump pliers to push the piston back in, but it doesnt seem to want to go in. The pads are currently stuck on solid so i cant slide everything up and over the disk!?
windsor
Re: newbie question im afraid
Post by windsor » Fri Aug 09, 2013 7:54 pm
Hit it with a lump of wood and a big hammer
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
timwilks13
Post by timwilks13 » Fri Aug 09, 2013 8:27 pm
worked a treat thanks! i was planning on but needed someone to confirm that as an acceptable method !
Post by dan_2k_uk » Fri Aug 09, 2013 8:28 pm
Hammers are always acceptable!
windsor
Post by windsor » Fri Aug 09, 2013 8:59 pm
If in doubt just remeber wd 40 gaffer and hammers are allways exeptable just dont use wd on ya brakes lol
1994 sj 413 sierra
cd players
99% rust free
alloys
bukets
suzukisteve
Post by suzukisteve » Fri Aug 09, 2013 11:57 pm
I believe the correct phrase is "if in doubt, give it a clout!" :lol: :thumbup:
pickle power!
Post by twiss » Tue Aug 13, 2013 10:56 am
I usually use a couple of large flathead screwdrivers to lever them off...
timwilks13
Post by timwilks13 » Tue Aug 13, 2013 11:08 am
the biggest issue was the pads were stuck on so couldn't get them over the lip of the disc so just used water pump pliers to open the pads and a pry bar and hammer to get em off!
Post by ScottieJ » Tue Aug 13, 2013 11:20 am
If just servicing the brakes, changing pads etc I just remove the small bolts on the sliders, then the caliper comes off without the pads ;)
I really disagree about the use of a hammer when it comes to brake callipers!!!!! You need to push the piston back in carefully and square to avoid damaging the piston or seal, some big pipe grips or a pry bar will do the job if you haven't got a proper piston winding tool.
Post by twiss » Tue Aug 13, 2013 11:24 am
Ohhh yeah scottie is right, usually its the slider bolts for me, then use screwdrivers to prize up the caliper if its a bit tight.
If you get a caliper winding tool (which are well handy) make sure you check you have the correct socket/spanner to use with it ;)
