serious lack of power
timwilks13
SCUK Website Padawan
Post by timwilks13 » Mon Aug 05, 2013 12:25 pm
went out properly for the first time last night with my new 1.3 fitted, 1st and 2nd pulled fine but the higher gears just didnt pull at all, i had more power from my 970cc. all plugs are firing, su needle is out 1.5 turns, compression test was fine. not sure whats going on and dont fancy doing 25mph all the way to wagtail. any clues as to what might be the cause?
Re: serious lack of power
Post by ScottieJ » Mon Aug 05, 2013 12:29 pm
Sounds like the air/fuel ratio is wrong.
There isn't a generic amount of turns that you need do on the SU mixture screw, all engines will need a slightly different adjustment.
http://sucarb.co.uk/technical-hif-type- ... ng-general
Post by Edweird » Mon Aug 05, 2013 12:39 pm
Could also be a timing issue. Over-retarded or over-advanced
timwilks13
Post by timwilks13 » Mon Aug 05, 2013 12:56 pm
checked the timing with timing light and its all fine. il have a fiddle with the mixture and see if i get anywhere!
timwilks13
Post by timwilks13 » Tue Aug 06, 2013 3:24 pm
when I wind the needle in alllll the way I can still drive it, that's not normal I'm guessing?
Post by ScottieJ » Tue Aug 06, 2013 4:00 pm
all that does is adjust the air fuel ratio, it should drive with it set anywhere really but won't necessarily be the correct mixture.
Do you know what spring and needle is fitted?
timwilks13
Post by timwilks13 » Tue Aug 06, 2013 4:22 pm
I think its a yellow spring, so know I need to get a red, and not sure of the needle, will strip it and see, didn't think the wrong needle and spring would make it this powerless though?
Post by Edweird » Tue Aug 06, 2013 4:24 pm
timwilks13 wrote:I think its a yellow spring, so know I need to get a red, and not sure of the needle, will strip it and see, didn't think the wrong needle and spring would make it this powerless though?
You'd be surprised. The wrong spring can make it massively over/underfuel.
timwilks13
Post by timwilks13 » Tue Aug 06, 2013 5:29 pm
am I just being an idiot because I can't find any float chamber springs anywhere on the sucarb site?
Post by dan_2k_uk » Tue Aug 06, 2013 5:47 pm
Their website has changed. I think because there are options for needles and springs based in the age of the carb you need to phone them.
