Vitara suspension
Vitara suspension
Post by donkeychomp » Thu Jul 04, 2013 10:54 pm
Before I spend a wad of dosh I need some clarification...will Grand Vitara coils and dampers fit a normal (lol) Vitara? If so will I encounter any problems with props etc? Just asking because the rears are pretty knackered and I'd rather spend my money on something that'll give the old girl a bit of lift.
Cheers, Alex
i_am_me
Re: Vitara suspension
Post by i_am_me » Thu Jul 04, 2013 11:06 pm
i fitted the gv springs to my vit and they went on fine.
only problem i had was the spacers that i have fitted aswell didnt sit right against the gv springs on the rear but i altered the spacers so they fit correctly.
but if you dont have spacers they will go straight on.
these were the ones i bought when i replaced my rears
http://www.ebay.co.uk/itm/Suzuki-GRAND- ... 35c3c4299c
If at First You Don’t Succeed Skydiving Is Not for You
Post by donkeychomp » Thu Jul 04, 2013 11:41 pm
Did you upgrade the dampers to GV as well? On ebay a set of those are £40, standard Vit ones are more like £90 which makes no sense to me!
Post by ScottieJ » Thu Jul 04, 2013 11:50 pm
If you want GV springs I have a set of my Gv2000
Post by donkeychomp » Thu Jul 04, 2013 11:54 pm
Nice one...thing is will they fit the standard Vit? Can you get a pic too?
i_am_me
Post by i_am_me » Fri Jul 05, 2013 3:45 am
on mine i have shock spacers to bring the shocks down a bit.but my shocks are still standard.
although mk2 astra rear shocks will fit on the back and are longer than standard vitara ones.
on the front you wont get enough articulation to warrant different shocks in my opinion.
Ladaman
Post by Ladaman » Fri Jul 05, 2013 8:18 am
My understanding is GV springs give a bit of lift, about 1.5" (37mm to you young un's), but reduce flex without shock extenders.
Have a look here http://yorkshire-suzuki.7forum.net/t669 ... ra+springs
Post by donkeychomp » Fri Jul 05, 2013 10:11 pm
Just checked out mk2 Astra shocks and holy shit...£20 a pair instead of £90 for Vit ones. Before I order these do they really fit? Not doubting anyone's integrity :brows:
Jamie_stafford
Post by Jamie_stafford » Mon Aug 26, 2013 3:10 pm
Yep they do fit, I fitted them on my brothers vitara and it worked really well, it was sat on standard springs with spacers and still had spring dislocation :-P
Suzuki, because life's to short to be fixing landrovers!
rory-ray
Post by rory-ray » Mon Aug 26, 2013 6:16 pm
Astra Mk2 shocks work fine, if you feel a bit fruity get the bilstien ones there about £50 a set, but standard are just as good.
You can also gain "3 off lift on the rear using Rover 600 springs. And 2.5/3" on the front using Mercedes 202 springs, but then you need diff brackets and helm spacer etc.
But IMO get Gv springs, for a full all round 1.5" lift. its safe and gives you enough for those rutted places
1994 Pick Up Converted Vitara
+2" Springs, Pro Comp Front And Rear Shocks, 31" Marshalls On 8j's, Front Winch Bumper, OMP Steering Wheel And Boss, Bucket Seats, Stripped Out, Black Bonnet With Scoop, Few Dents And Scratches, Little Rust!!!
