Engine not ticking over
wollaston
Post by wollaston » Fri Jun 28, 2013 10:55 am
Hi can anyone help me please . I've got a sj 413 with a 1.6 8v vitara engine I've had all the plugs and leads changed . But when I go 2 start it I have two have the throttle wide open and it's only just ticking over about 1.5 rpm . soon as I let the throttle of the engine just cuts out any ideas .
suzukisteve
Re: Engine not ticking over
Post by suzukisteve » Fri Jun 28, 2013 10:59 am
have you checked that you're getting enough fuel up mate? if you whip a fuel line off and turn the engine over you should get a fair squirt out. if not check the fuel filter isn't blocked up
pickle power!
Post by turbo-tom » Fri Jun 28, 2013 11:03 am
Can be blocked fuel/carb needs tune
Blocked airfilter
Or weak coil
Post by ScottieJ » Fri Jun 28, 2013 11:06 am
Try changing the fuel filter.
Are you running the standard 1.6 carb? if so is the fuel stop solenoid wired up?
wollaston
Post by wollaston » Fri Jun 28, 2013 11:17 am
It's a su carb on it I've checked the fuel it's got a good squirt I haven't checked the coil yet
Post by twiss » Fri Jun 28, 2013 12:24 pm
I'd check the coil. Mine is doing the same thing. Won't idle unless the idle stop screw is wound all the way in. Ive just replaced the HT leads and its made a hell of a difference!
I can tell its the coil, as my temp gauge takes its power from there... when the coil is under load, my temp going up 20 degrees, then it drops off again when you put your foot on the clutch.
I just bought an uprated MSD blaster 2 coil... Only £45... I will post up how well it works!
Post by turbo-tom » Fri Jun 28, 2013 12:51 pm
Yeah mate id be interestwd what differance it makes as I might get one! :)
wollaston
Post by wollaston » Sun Jun 30, 2013 4:56 pm
Changed coil no change that was a waste of time
Post by twiss » Sun Jun 30, 2013 5:57 pm
Mine was the coil in the end... it really goes like stink now :)
First, has the timing been adjusted and is it in the right place?
Second, have you just put the SU on? assuming the mixture and idle are making no difference, is the vacuum advance connected? most SUs have advance at zero throttle, so if thats the case it will be putting your timing off
Post by ScottieJ » Sun Jun 30, 2013 7:58 pm
So did it run before the plugs and leads were changed? Has anything else been changed since it last ran?
Can we have some pics of how the carb is set up please.
Cheers.
