hotwire from under the bonnet
fozzyx123
Post by fozzyx123 » Mon Jun 17, 2013 8:22 pm
after ripping out my dash!!!!!..is it possible to start my sj413 from under the bonnet so i can work out the wires to fit a switch? ...ive got wiring diagrams but its just not working, is thier a hidden fuse somewhere as i now no longer even get an ignition click
OllieSJ
Re: hotwire from under the bonnet
Post by OllieSJ » Mon Jun 17, 2013 8:29 pm
there is a small wire will get a pic tomox if needed
mk1joe
Post by mk1joe » Mon Jun 17, 2013 8:30 pm
run a live wire to the positive of the ignition coil and bridge the starter motor solenoid.
i think thats all?
please correct me if im wrong people:)
fozzyx123
Post by fozzyx123 » Mon Jun 17, 2013 8:47 pm
will try now
fozzyx123
Post by fozzyx123 » Mon Jun 17, 2013 8:53 pm
have bridged the selonoid and that spins..but no ignition turnover
Post by Edweird » Mon Jun 17, 2013 9:06 pm
Use a jump lead to turn it over.
mk1joe
Post by mk1joe » Mon Jun 17, 2013 9:08 pm
you mean its not turning the engine over? hmm, try feeding power to the smaller wire on the starter instead?
fozzyx123
Post by fozzyx123 » Tue Jun 18, 2013 7:28 pm
right...good news.....managed to fire the engine up!!!!
here's the thing...i ran a wire from the small wire where you said direct to the battery, then a live where from the solonoid to the battery, question is....will anything burn out between directly linked or now?
Post by ScottieJ » Tue Jun 18, 2013 7:54 pm
You just want it wired up as normal, I.e the large wire from batt to starter and the earth wire attached to a starter bolt.
Then bridge a fused live to the ignition coil. Then all you need to do is put a wire on the spade terminal on the starter and connect it to the battery positive to turn the starter and get it started, then disconnect it once its running.
fozzyx123
Post by fozzyx123 » Wed Jun 19, 2013 12:03 pm
will take pictures and post them on here so you can see what i have done then point out the obvious to me if you don't mind....lol.... yes im a self confessed dumbass!!!!
