Shortening steering column
Posted: Sun May 26, 2013 11:05 am
With the Jimny PAS box the steering column to far too long.
I remember reading somewhere about the plasic pegs. I've drilled them out but it still wont slide. Do i need to pull it apart and chop some of the thin part?
Or have i just not wire brushed enough and hit it hard enough?
Re: Shortening steering column
Posted: Sun May 26, 2013 11:13 am
by dan_2k_uk
I had this problem. Ended up cutting down the splined shaft on the Jimny box and grinding a new releif where the bolt goes thru the clamp.
Posted: Sun May 26, 2013 11:17 am
by ferris
I just hit mine really hard with a hammer and it went eventually. But don't hit it to far, cause it wont come back out again.
Posted: Sun May 26, 2013 11:26 am
by dan_2k_uk
The only problem I see with collapsing it is that ammount of travel is supposed to be there to stop it spearing your chest in a crash.
Posted: Sun May 26, 2013 12:23 pm
Hammer method. It did not want to budge though.
Its on now!
Posted: Mon May 27, 2013 1:07 pm
by Rhinoman
dan_2k_uk wrote:The only problem I see with collapsing it is that ammount of travel is supposed to be there to stop it spearing your chest in a crash.
If it has to be hit that hard with a hammer its not going to give in a crash anyway. I would assume that they slid a little easier when they were new.
