With the Jimny PAS box the steering column to far too long.
I remember reading somewhere about the plasic pegs. I've drilled them out but it still wont slide. Do i need to pull it apart and chop some of the thin part?
Or have i just not wire brushed enough and hit it hard enough?
Shortening steering column
Re: Shortening steering column
I had this problem. Ended up cutting down the splined shaft on the Jimny box and grinding a new releif where the bolt goes thru the clamp.
![Image](http://i291.photobucket.com/albums/ll288/dan_2k_uk/33SIG_zpse27c5da7.png)
I just hit mine really hard with a hammer and it went eventually. But don't hit it to far, cause it wont come back out again.
The only problem I see with collapsing it is that ammount of travel is supposed to be there to stop it spearing your chest in a crash.
Hammer method. It did not want to budge though.
Its on now!
Its on now!
If it has to be hit that hard with a hammer its not going to give in a crash anyway. I would assume that they slid a little easier when they were new.dan_2k_uk wrote:The only problem I see with collapsing it is that ammount of travel is supposed to be there to stop it spearing your chest in a crash.
