carb vent tube
jloza
carb vent tube
Post by jloza » Mon May 13, 2013 4:57 pm
hi everybody iam new to this forum does anyone know where i can get a carb venturi tube or if one could be made it doesnt look to complicated i have a 1988 suzuki samurai i found one online but shipping was almost the same as the price for the part iam sure its not hard to make. any info will help
Re: carb vent tube
Post by Jordi » Mon May 13, 2013 5:36 pm
Which pipe? might have spare
jloza
Re: carb vent tube
Post by jloza » Mon May 13, 2013 11:01 pm
its the one that goes into the carb by the butterfly its called venturi tube u can google it for a better idea of what it is and looks like
thanks jerry
Re: carb vent tube
Post by Jordi » Mon May 13, 2013 11:13 pm
Not sure which one it is. Is it a metal pipe on the actual carb? (Been a while since i had anything to do with standard carbs)
If so i'm bound to have one, i have carbs coming out of my ears.
Tried googling for it but couldn't find a decent image.
Re: carb vent tube
Post by ScottieJ » Tue May 14, 2013 9:52 am
Do you not have a local suzuki dealer?
You should be able to get it from them. The part number is 13211-831Z0
http://www.acksfaq.com/TS_4-06_03109.htm
http://www.lowrangeoffroad.com/index.ph ... -tube.html
