What size are the caliper bolts on a LWB Vit
Posted: Sun Mar 03, 2013 9:07 am
by justaddmud
I recently bought from a scrapper some front calipers and carriers from a 91 (i think) lwb 16v Vit however i didnt get any bolts other than the small ones that hold the caliper to the carrier.
I thought they would be the same size and thread as the old one but boy was I wrong, spent an hour yesteday walking around a breakers undoing random carrier bolts on random cars to see waht would fit and nothing did.
Are these bolts Imperial or something and if so does anyone have a clue what the thread/size is as i could have finished off my front end yesterday if I had those 4 bolts
Ian
Re: What size are the caliper bolts on a LWB Vit
Posted: Sun Mar 03, 2013 11:32 pm
by Darrell
I've been through a shed load of diagrams and they all show M12 x 33 or 32mm (same as the SJ)
Can't think what you have, sorry
Posted: Mon Mar 04, 2013 12:08 am
by Darrell
Why can't I see a thread in those holes.. I'm confused
Posted: Mon Mar 04, 2013 9:07 pm
by justaddmud
There is a thread there, promise.
they are pretty rot as they were left outside on the car (but with no bolts) maybe i just need to get a tap on them and clean them out, thought winging a correct bolt in slowly with a lot of WD would do the trick.
m12x32/33 that sounds like an odd size
Posted: Mon Mar 04, 2013 9:32 pm
They should be metric, and with how suzuki standardise a lot of things so I would imagine the thread should be the same as the Sj caliper hangers.
Posted: Mon Mar 04, 2013 10:03 pm
by Darrell
justaddmud wrote:There is a thread there, promise.
All the diagrams listed either
M12 x 32mm long or
M12 x 33mm long
None gave the thread pitch which is normally fine on these bolts.
Hope that's a bit clearer
Posted: Wed Mar 06, 2013 6:00 pm
by justaddmud
Right got ya, couldt place the 32/33 bit, but length makes a lot more sense :-)
i will clean the threads out a lot and just try some other spare bolts i picked up for now, then go back to the breaker and get some longer ones fron the Frontera i found there
Ian
Posted: Wed Mar 06, 2013 7:14 pm
by justaddmud
metric fine it is then
cleaned the threads even though they didnt look too bad, used an old bolt, would it right in
so what have we learn't today?
clean stuff, and it stops you looking like a muppet
Posted: Wed Mar 06, 2013 7:18 pm
by Darrell
Muppet
