Fitting a tow bar ... maybe ?
clubbysj
Post by clubbysj » Fri Apr 17, 2009 7:20 pm
Thinking of fitting a tow bar to the back of my Sj / Mini. From what i can gather, they bolt to the underside by 4 ( i think ) bolts.
However .... after having a look at the rear underneath, i'm not sure if i've got the correct mounting holes or if it will even fit due to me having the Clubman Estate body.
Does it use the 4 ( 2 either side ) holes that are used for towing eyes ?
Is there any chance that someone on here, with a towbar fitted, could show me a couple of pics of where it is mounted, and how it all fits / looks etc.
Hoping to get a small trailer in the future for chucking all my bits in when i go to shows, so fingers crossed i'll be able to get a tow bar that fits okay.
Daz
carnut
Re: Fitting a tow bar ... maybe ?
Post by carnut » Fri Apr 17, 2009 8:30 pm
i got a tow bar here if your intrested.. it bolts onto the rear of the chassis legs, picking up the four (two each side) holes. then goes down below the tank, and has the bracket which uses the front tank mounts. also comes with a ball hitch. hope that fitting instruction makes sense, if not pm me!.
andy
