I bought my first SJ410 to try some off roading 2 months ago and loved it!!
Ever since ive spent all my spare time and money on moding it
It has a 2 inch shackle lift front and rear and a snorkle apart from that it was standard.
Just bought some vitara fat boy alloys and new 31 inch mud tyres which look sweet if only i could turn more than a quarter of a turn before they hit on the arch!!
Which brings me to my next point, i need to raise it by a couple inches.
I went through every option-
SOA - alot of work and needed to mod to many things
RUF with bedford rears - want to coil spring it eventually
AAL - hurd this makes the ride really hard + longer hoses etc etc
So i decided on a 2 inch body lift, the only thing i could really find on this forum about it was that a couple of guys did it in a hour from start to finish and it was really easy.
Lets just say i started it 4 days ago and im not even half way through
As far as i can see there is 10 nuts or bolts that hold the shell to the chassis.
2 bolts at front = np
2 bolts at rear = np
4 nuts under the chassis behind the front seats, the inside 2 i ground the heads off the studs and knocked them through. But the outside ones u can not see the tops of the studs. The only way i can see how to do this is to cut 2 massive holes in the panels inside the car to get to the heads of the thread as it sits between the inner wheel arch and those panels?? Ive allready cut a hole in the inner arch to see it and i cant get to the head lol guess i need to weld that up soon!
Also the 2 studs where the drivers and passengers feet would be, i can not for the life of me see where these go to inside the car. Have i got to cut the floor open here aswell and grind them off as i think its double skined??
Any help really appreciated as me trucks starting to look like frankenstein!!
Thx Rich
