Wiring radio
Crisdolf
Wiring radio
Post by Crisdolf » Sat Nov 10, 2012 5:52 pm
Anybody had any problems wiring a radio in ? My Zuke had the block there so wired to that,it works on the ignition but when it's switched off it goes dim and no sound the only way to stop this is to switch it off on radio ???
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Wiring radio
Post by Darrell » Sat Nov 10, 2012 7:48 pm
Had a block to wire into :er: . What luxury, mine had all of two wires. Live from ignition and an earth :D
Re: Wiring radio
Post by turbo-tom » Sat Nov 10, 2012 8:56 pm
that is a luxary mine came with no hole no wiring and no block :lol:
Re: Wiring radio
Post by Darrell » Sat Nov 10, 2012 8:58 pm
Can you whistle a good tune :D
Re: Wiring radio
Post by turbo-tom » Sat Nov 10, 2012 9:00 pm
Darrell wrote:Can you whistle a good tune :D
:lol: :lol:
nah i would rather listen to the bangs and rattles :brows:
Re: Wiring radio
Post by Tramp » Sat Nov 10, 2012 9:09 pm
Mine had an ISO socket soldered into the loom, it sounds like yours is having issues with the switched live & the constant live, I'm guessing that you have yours mixed up (red & yellow in the iso harness) so its trying to pull the volts through the switched supply instead of the fused live, try swapping them over
Crisdolf
Re: Wiring radio
Post by Crisdolf » Sat Nov 10, 2012 9:27 pm
All sorted now she bounces up the road to the tunes lol
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Wiring radio
Post by Darrell » Sat Nov 10, 2012 9:45 pm
"nah i would rather listen to the bangs and rattles :brows:"
What! Drum & bass :D
Re: Wiring radio
Post by turbo-tom » Sun Nov 11, 2012 10:54 am
Darrell wrote:"nah i would rather listen to the bangs and rattles :brows:"
:hahaha: :hahaha: :hahaha: :hahaha: :hahaha: :hahaha:
