Removing d-flex ?
martynf
Removing d-flex ?
Post by martynf » Mon Apr 13, 2009 10:46 pm
Hi guys,
My sammi is a pig to drive on road, no, I mean a PIG doesn't even come close! its awful!! :O
Its spring over axle with d-flex, the dflex just HAS to go!
So here's my question:
I remove the dlfex and fit what in their place front and rear??
What is the best thing to fit? standard shackles? or....
Thanks in advance
Martyn
91 LWB Chassis with a new '92 built Euro body'
Its too good to offroad now..... looks like I'll be getting a second one to get dirty with :)
bourneyo
Re: Removing d-flex ?
Post by bourneyo » Tue Apr 14, 2009 2:29 pm
Standard shackles!
if you put extended shackles on it would kill your springs in a very short space of time! especialy as you are SPOA! it could also result in your SJ being very unstable, SPOA gives about 5" of lift, lifting shackles are usualy 2-3" that would give a min of 7" lift, and on a narrow vehicle can only result in tears!
Dan 8-)
martynf
Post by martynf » Wed Apr 15, 2009 12:12 pm
Thanks Dan,
Guess I knew the standard ones answer, just wanted to hear it form someone with more SJ experience than I have. You never know.... so best to ask.
Thank you!
Martyn
