Any one good at wiring
choochoo
Post by choochoo » Mon Oct 22, 2012 8:29 pm
Hi
I've booked this week off work to get my sj back together ,all going well till it comes to wiring.
I've got the main power wire from + to starter motor but some where I've lost the power for rest of the electrics . I've put a + to a white thick wire and got ignition and engine turns over but no spark. Previous owner have fitted there stupid switches to use as a silly anti theft device but now it's just a pain in the back side.
If I put some pictures up any one willing to help ;)
I'D RATHER PUSH MY SUZUKI THEN DRIVE A LANDROVER
Christoff
Re: Any one good at wiring
Post by Christoff » Mon Oct 22, 2012 8:47 pm
Always going to be difficult when wiring has been previously modified. Makes any wiring diagrams useless.
What isn't working then now and what has been modified as far as you know?
Could you maybe find a standard loom to use instead ?
Post by Darrell » Mon Oct 22, 2012 8:50 pm
well here's a start.........
Headlights shown switched earth (some spanish models are switched live).
Headlamp Circuit.jpg (120.99 KiB) Viewed 7682 times
413 Ignition circuit.jpg (20.18 KiB) Viewed 7682 times
indicator circuit.jpg (51.42 KiB) Viewed 7682 times
Supply with altnernator.jpg (70.39 KiB) Viewed 7682 times
choochoo
Post by choochoo » Mon Oct 22, 2012 9:03 pm
those pictures help alot thanks.
Any idea what this plug is for?
Post by Darrell » Mon Oct 22, 2012 9:08 pm
Nope, or the fuses :S
choochoo
Post by choochoo » Mon Oct 22, 2012 9:10 pm
looks like its had an alarm in the past so its probley from that then, ill have to trace to where it goes to and ill try out the coil diagram tomorrow and see if i get a spark :)
Thanks For The Help
