rear shocker problems
Christoff
Post by Christoff » Mon Aug 06, 2012 12:55 pm
Hello,
Can anyone tel me what thread size is the stud that comes off the body for mounting the rear shockers to. I think its M12 but not sure on the pitch
Seems to be quite a fine thread
Everytime i tighten a nut onto it it strips the nut of its threads so i think the threads on the stud are damaged
I have got some daft set up at min where the mounting point for the shockers is lowered so i can use standard shockers, need tome extended shockers really
Re: rear shocker problems
Post by ScottieJ » Mon Aug 06, 2012 1:59 pm
Christoff
Post by Christoff » Mon Aug 06, 2012 4:22 pm
nice one scotty. I noticed that they fit so i ''borrowed'' one nut from each half shaft but ended up stripping them both
Any recomendations on a set of extensed rear shocks to fit a 2" lift? Some that use the original mounts so i can bin these lowered mounting points?
Christoff
Post by Christoff » Mon Aug 06, 2012 5:23 pm
Scotty, i bought them nuts from muddyzook for the halfshafts, could do with replacing them anyway theyve been off a few times
Found these on bits4vits
http://www.bits4vits.co.uk/store/nuts-3 ... d_548.html
These have nylock thread so shouldnt come loose
The nuts i had on the shockers previously did come loose and started rattling, do you think its because they werent nylock or didnt have the locking washers like on the halfshafts?
Post by ScottieJ » Mon Aug 06, 2012 7:13 pm
Those you linked to are m10 so too small ;)
I've never had a problem with those bolts coming loose, you could use spring washers or nylocs to prevent it happening though.
As for shocks I run kyb excel-g shocks, seem to do the job for a budget. Might be worth contacting them to see if they do a similar valving and mounts to stock but longer.
