down to earth
suzukisteve
down to earth
Post by suzukisteve » Thu Jun 21, 2012 9:35 am
morning everyone.
fitted my new spots last nite :hands:
basically took the bump stops out above the windscreen and used the holes to mount the spots in. :tongue:
the question is when i go to wire them in today (hopefully. bloody weather :roll: ) am i right in saying
that it wont earth on the windscreen, where i mounted the lights, due to it bein a fold down windscreen and thus surrounded in rubber?
if so is there any recommended area to position the earth??
cheers
steve
pickle power!
Re: down to earth
Post by Tramp » Thu Jun 21, 2012 10:26 am
I imagine it will earth through the hinges at the bottom, but its good practice (and stops you scratching your head later when you get an issue) if you run a seperate earth, when I mounted spot lights on my roof I ran a section of 2.5mm twin core and earth which comes flat and is what you use in house wiring on a 240v socket ringmain, this I glued to the inside of the windscreen surround, at the top I fitted a connector and ran the rest of the wiring to the spots in flex, with the connector you can disconnect it whilst removing the soft top & it makes the job a bit easier! The twin core & earth (that was glued to the inside of the screen) I painted black & powered from a relay under the dash, it doesn't look overly bad even if I do say so myself!
A picture of my switches
And my wiring, you can see the connectors
I have to add.... its a nightmare trying to link to Photobucket images on your phone!
suzukisteve
Re: down to earth
Post by suzukisteve » Thu Jun 21, 2012 11:09 am
ah fantastic!
yeah im gonna be runnin mine trhu a relay and a fuse as well, just so its done proper like.
and the previous owner had cut a hole in the dash, a perfect size for the switch i have!
cheers dude!!
pickle power!
suzukisteve
Re: down to earth
Post by suzukisteve » Thu Jun 21, 2012 11:11 am
i'll put some :snap: when im done!
cheers matey!
pickle power!
Re: down to earth
Post by dan_2k_uk » Thu Jun 21, 2012 5:47 pm
There is a fly lead between the body tub and the screen surround internally as it needs the earth for the wiper motor.
Re: down to earth
Post by dan_2k_uk » Thu Jun 21, 2012 5:51 pm
Tramp wrote: I have to add.... its a nightmare trying to link to Photobucket images on your phone!
What phone? I just pop the app up. Tap 'show links' then tap the img code (which auto copies the same as the pc site) and paste it to my post.
Dan
Re: down to earth
Post by ScottieJ » Thu Jun 21, 2012 5:53 pm
dan_2k_uk wrote:There is a fly lead between the body tub and the screen surround internally as it needs the earth for the wiper motor.
I was gonna say I thought there was an earth between the surround and body.
Re: down to earth
Post by Tramp » Thu Jun 21, 2012 8:22 pm
What app? Runner still doesn't work for me so I do it all through the browser...
Re: down to earth
Post by dan_2k_uk » Fri Jun 22, 2012 12:11 am
Photobucket app. I use my browser for the forum and just use the task switcher on the phone to swap between the browser and the photobucket app.
suzukisteve
Re: down to earth
Post by suzukisteve » Fri Jun 22, 2012 10:12 am
ah nice one guys, that'll tidy things up a bit!
weather was sh*te last nite so hopefully tonite is a goer!
pickle power!
