had a beauty today
welding up the rear drivers side arch on the 410 when there was a large flash.
turns out i had a little leak in the fuel line oooopppphhhh very close
quick shower and change ov underwear after that.
i must have nicked a rusty spot on the line with the wire brush taking the muck off underneath.
lesson learned
bantam
close calls !!!!!!!!
pull it back and clean it properly !!!!!
Re: close calls !!!!!!!!
haha i bet made you jump lol, smell of hair burning un mistakable lol
i set fire to a volkswagen camper once?? (actually it was a customers), jes they go up quick when petrols involved...always drain and remove the tank now, even though it might take an hour or so.. they say you always learn the hard way
should have filmed it, you'd of had £250 from 'you've been framed' bet it was hilarious
Luke
Luke
i seen somebody cut through a fuel line on a customers car with oxy/acet the owner of the garage ran over with the fire extinguisher and put the car out first it was hilarious then help the bloke outcarnut wrote:i set fire to a volkswagen camper once?? (actually it was a customers), jes they go up quick when petrols involved...always drain and remove the tank now, even though it might take an hour or so.. they say you always learn the hard way
- urbanzook
- Winching along now
when i was stripping my anus i found gas in the tank at this time it was still on the
chassis but the chassis was mostley stripped ie no body lump ect, so me an my mate
tiped it ova an used the filler pipe to fill a jerry can, i no now that id bin better off taking
the tank off an doing it that way, but hay we do wat we do and make a mess doing it the
hard way then my mate has a brain storm burn off the spilled gas, so i go for my phon and
stand back wanna see wat happend take a look is only short as i had to go put it out.
http://www.youtube.com/watch?v=iybDDLgx ... annel_page
Well...thats just made up my mind 4 when i weld my cage n sliders...!
my ride.........
my ride.........
