friggin sj brakes
logger
friggin sj brakes
Post by logger » Fri Apr 06, 2012 11:25 pm
the brakes on my sammy are a pain in the arse. i don't use the car very often then when i do one side will seize on pulling me across the road and i have to strip it all to bits
it normally sticks after offroading
is this common?
any ways to stop it? eg different calipers?
dazerede
Re: friggin sj brakes
Post by dazerede » Fri Apr 06, 2012 11:38 pm
when you park your car dont use your handbrake or brakes just put it in gear and use some thing to block the front wheels it happend on my truck when i left the handbrake on back wheels locked on when i moved the vehicle
4” calmini lift kit :)
logger
Post by logger » Sat Apr 07, 2012 1:49 pm
Its the front brakes that stick!
Post by Darrell » Sat Apr 07, 2012 2:15 pm
Yes it's a common problem, I had to strip and clean mine only a couple of weeks back as one was dragging and over heating :evil:
I believe they can be swapped for vitara brakes IE caliper and vented discs, but am unsure which model SWB or LWB. Reconditioned SJ calipers are about £100 each so not ideal. You can get seal/refurb kits for the SJ from "brakesinternational" but these are not on there website, you have to ring them. I have no idea what these cost though or quite what you get (just a seal and dust cover?? or piston as well??). Or just struggle on saying I'll change the buggers next time, but just clean them up again, or is that just me ;)
logger
Post by logger » Sat Apr 07, 2012 3:50 pm
They are a lot better now I've cleaned them but I must have got some grease on them somewhere.
I suppose I'll just have to strip them every time I go to a p+p
Post by twiss » Sun Apr 08, 2012 2:31 pm
We have a Suzuki Club UK writeup for rebuilding your brake calipers. Here you go...
http://www.suzukiclubuk.co.uk/diy/18-wh ... er-rebuild
Probably cheaper than replacing them!
