alternator
alternator
Hi every one and have a great new year forget the ups and downs just take your tea flask and go for a drive in your good old SJ there great for feeling alive
, Now I have a SJ 413, 1324cc year 1988 and the alternator is the normal one fitted as standerd I think about 35A ok as standard but these days a bit of a joke I need to fit one about 80-100 amps have you any ideas of one that will fit in same place? This SJ is a one off, as I brought it a year ago now from Dublin where it was locket up for the past 17 years so its only got 36K on the clock, so you see its like finding pure gold…… sorry if I’ve been going on……
Re: alternator
hi, don't know of a bigger alternator that'll fit in original place, but on a previous sj i had i fitted a 2nd alternator to assist with charging 2 batteries for using winch. this was easy to do using simple mount bracket and adding another pulley to crank pulley. then its just a case of running a power feed, earth and seperate waring light.
if u are anywhere near brighton i might still have the bits at the back of the shed.
hope this helps.
Kev
hope this helps.
Kev
- firemansam
Re: alternator
I had an 80 amp alternator from SJ UK for about £60 a couple of years ago.
Theyve changed their name now and i cant remember what it is...
anybody know?
anybody know?
Re: alternator
They are now called 'parasource 4x4 offroad systems'
Dan
Dan
- urbanzook
- Winching along now
Re: alternator
stay a way they changed there name coz off bad press from ebay.
ie there extended shocks set £9 astra belmont shocks with a bar that dont fit, £150
2"lifted springs 7month for them to come.
an arse owner that lies.
i can go on but thats not wot we are about. just be worned.
the alto you may have got may not be wot it says it is.
and dont let him tell you they have never had a problem befor as i no 5 sj lovers that have.
if you can talk to the old boy in the shop (shead iv bin there not wot you think) he nos his stuff
and is wicked. but id never yous them for parts.
- firemansam
Re: alternator
yeah i guessed as much :/
dw i checked the output of the alternator when it was up and running
beats that 35amp one LOL
