Electronic ignition
Posted: Mon Nov 21, 2011 6:27 pm
by chrisj410
I'm gonna get rid of them points, I've got a spare Sammy distributor, now will the 410 coil be man enough? Or do I need to track down a Sammy one?
Cheers Chris
Re: Electronic ignition
Posted: Mon Nov 21, 2011 8:28 pm
by rgonzobull
Ill be corrected no doubt, but if the sj coil has an external ballest resistor you are best to use the sj413 coil.
Posted: Mon Nov 21, 2011 8:43 pm
by Darrell
Ill be corrected no doubt, but if the sj coil has an external ballast resistor you are best to use the sj413 coil.
I agree
Posted: Mon Nov 21, 2011 9:47 pm
by Christoff
Why is that just out of interest ?
Posted: Mon Nov 21, 2011 10:19 pm
by rgonzobull
I believe its to do with the internal resistance of the coils being different and the electronic sj413 dizzy does not like it. I'm sure someone will be along soon with the correct technical info.
Posted: Mon Nov 21, 2011 10:33 pm
by Darrell
Only because you know that you are using the correct coil to match electronic ignition.
Well had to go search for some info to see what the differences are.
410 coil primary windings = 1.5 ohms secondary 10,000 ohms
413 coil primary windings = 1.35-1.65 ohms secondary 11,000 - 14,500 ohms
Much the same on the primary, but not sure how they would behave as the 410 coil is fed about 9v after the ballast resistor apart from starting.
The 413 coil is fed 12v all the time.
So as long as the 410 coil is still used with the ballast resistor I would assume it would be ok, however I would think the 413 coil would give a slightly better/bigger spark
Hell, what do I know
"Only because you know that you are using the correct coil to match electronic ignition"
Posted: Tue Nov 22, 2011 9:35 am
I would use a 413/samurai coil just for the fact that is what it originally ran with.
Posted: Tue Nov 22, 2011 9:52 am
by chrisj410
Sweet I'll track one down thanks for the replys
Posted: Tue Nov 22, 2011 10:15 am
Any motor factors should be able to get them.
Posted: Tue Nov 22, 2011 11:23 am
by chrisj410
Found one in me shed think it's a samurai coil, not sure
I'll try a motor factors later thanks
