Electronic ignition
chrisj410
Electronic ignition
Post by chrisj410 » Mon Nov 21, 2011 6:27 pm
I'm gonna get rid of them points, I've got a spare Sammy distributor, now will the 410 coil be man enough? Or do I need to track down a Sammy one?
Cheers Chris
rgonzobull
Re: Electronic ignition
Post by rgonzobull » Mon Nov 21, 2011 8:28 pm
Ill be corrected no doubt, but if the sj coil has an external ballest resistor you are best to use the sj413 coil.
LJ80Q
Post by Darrell » Mon Nov 21, 2011 8:43 pm
Ill be corrected no doubt, but if the sj coil has an external ballast resistor you are best to use the sj413 coil.
I agree :thumbup:
Christoff
Post by Christoff » Mon Nov 21, 2011 9:47 pm
Why is that just out of interest ?
rgonzobull
Post by rgonzobull » Mon Nov 21, 2011 10:19 pm
I believe its to do with the internal resistance of the coils being different and the electronic sj413 dizzy does not like it. I'm sure someone will be along soon with the correct technical info.
LJ80Q
Post by Darrell » Mon Nov 21, 2011 10:33 pm
Only because you know that you are using the correct coil to match electronic ignition.
Well had to go search for some info to see what the differences are.
410 coil primary windings = 1.5 ohms secondary 10,000 ohms
413 coil primary windings = 1.35-1.65 ohms secondary 11,000 - 14,500 ohms
Much the same on the primary, but not sure how they would behave as the 410 coil is fed about 9v after the ballast resistor apart from starting.
The 413 coil is fed 12v all the time.
So as long as the 410 coil is still used with the ballast resistor I would assume it would be ok, however I would think the 413 coil would give a slightly better/bigger spark :er:
Hell, what do I know :oops:
"Only because you know that you are using the correct coil to match electronic ignition" :thumbup: :D
Post by ScottieJ » Tue Nov 22, 2011 9:35 am
I would use a 413/samurai coil just for the fact that is what it originally ran with.
chrisj410
Post by chrisj410 » Tue Nov 22, 2011 9:52 am
Sweet I'll track one down thanks for the replys
Post by ScottieJ » Tue Nov 22, 2011 10:15 am
Any motor factors should be able to get them.
chrisj410
Post by chrisj410 » Tue Nov 22, 2011 11:23 am
Found one in me shed think it's a samurai coil, not sure
I'll try a motor factors later thanks
