Pro Comp Shocks
charger
Pro Comp Shocks
Post by charger » Mon Nov 14, 2011 8:21 pm
Does any one run these ?? I'm after the part number for the +2" ES9000 been offered a new set cheap.
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Re: Pro Comp Shocks
Post by turbo-tom » Mon Nov 14, 2011 9:26 pm
i run pro comp shocks cant remember what model i got , but there strong , dont leak , do the job so at the end of the day i would recommend them :rockin:
chrisj410
Re: Pro Comp Shocks
Post by chrisj410 » Mon Nov 14, 2011 9:28 pm
I run pro comp es3000 and rough country hydro 8000 think there both really good, the es2000 are aparently softer so they must be good
charger
Re: Pro Comp Shocks
Post by charger » Tue Nov 15, 2011 9:41 pm
I have been offered ES900s they are 14" & 22.5" Extended will that work with an add a leaf lift?
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Re: Pro Comp Shocks
Post by ScottieJ » Wed Nov 16, 2011 12:23 pm
ES9000s are far too hard for an SJ, they are what most people use on land rovers
charger
Re: Pro Comp Shocks
Post by charger » Wed Nov 16, 2011 12:53 pm
ScottieJ wrote:ES9000s are far too hard for an SJ, they are what most people use on land rovers
Would they cause damage or just be a harsh ride.
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Re: Pro Comp Shocks
Post by ScottieJ » Wed Nov 16, 2011 12:55 pm
won't cause any damage but Yes they would make the ride very firm.
charger
Re: Pro Comp Shocks
Post by charger » Wed Nov 16, 2011 12:57 pm
I can live with that do the sizes sound ok for the add a leaf lift
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Re: Pro Comp Shocks
Post by dan_2k_uk » Wed Nov 16, 2011 1:05 pm
Off the top of my head they sound a touch long. Think my 3000's were slightly shorter for a 2" lift.
Don't quote me on that!
Dan
Re: Pro Comp Shocks
Post by ScottieJ » Wed Nov 16, 2011 1:10 pm
Ermmm trust me if you go for the combination of add-a-leafs and ES9000s you might as well just bolt your axles to the chassis :lol:
The length sounds about right, maybe a bit long? you need to flex it up and measure the open and closed lengths between the mounts without shocks on really.
