steering stabilizer
steering stabilizer
After fitting my add a leaf I'm having problems getting the steering stabilizer back on( I thought it was called a track bar but the haynes calls it this) I don't mean the steering damper either. Any tips on getting it back on. Also the rear shocks are too short but after a short drive it makes no difference.
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: steering stabilizer
are you running long shackles as well? you should be able to lift it around 3" before you have problems with the standard steering set up?
Pics please
Pics please
Got it back on
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Glad to hear it, sorry that the forum disappeared shortly after you asked the question.
