410 dizzy
spanish sammy
410 dizzy
Post by spanish sammy » Sat Aug 27, 2011 12:09 pm
seems the most bizzare thing but can i put a 410 points and condenser on my 1.6 vitara engine???
Re: 410 dizzy
Post by ScottieJ » Sat Aug 27, 2011 2:07 pm
You could but why would you want to? The standard electronic ignition produces a stronger spark.
spanish sammy
Re: 410 dizzy
Post by spanish sammy » Mon Aug 29, 2011 4:35 am
its back to being covert im afraid i may need to fit the 410 dizzy to armour my ( no its definately a 1000) arguement but thanks for the answer
Re: 410 dizzy
Post by ScottieJ » Mon Sep 05, 2011 3:22 pm
spanish sammy wrote:its back to being covert im afraid i may need to fit the 410 dizzy to armour my ( no its definately a 1000) arguement but thanks for the answer
I'm a bit confused by this reply :lol: I was just saying why would you want to swap it over to points when they are less reliable than the electronic ignition set up. The 413/vit dizzy and coil is a common upgrade for 410s and people often say that it makes the engine run a lot better. They also don't need replacing or setting up as often. I used to carry a set of feeler gauges with me at all times in case my points needed adjusting, it was a pain in the arse :lol:
Why is it that you want to run points?
Re: 410 dizzy
Post by Edweird » Mon Sep 05, 2011 4:41 pm
Because his truck needs to look like a 410, even if the engine's capacity is 1.6, because he's not supposed to upgrade it.
Re: 410 dizzy
Post by ScottieJ » Mon Sep 05, 2011 4:49 pm
Ah yeah I get it now :oops: I forgot that he wasn't allowed to mod his sj! well the dizzys look almost exactly the same from the outside
would they take the dizzy cap off in an inspection?
Re: 410 dizzy
Post by Edweird » Mon Sep 05, 2011 5:37 pm
I suspect it'll be a quick look-see, but if the electronic ignition stuff's visible, then he'll have a problem.
