Tighten Wheel Bearing
Posted: Fri Jul 22, 2011 1:30 pm
by Rjmaas512
Quick Question,
How do you tighten the free wheeling bearings on an SJ (Spanish Module).
Looking in the manual now but thought I'd ask anyway.
Re: Tighten Wheel Bearing
Posted: Fri Jul 22, 2011 1:55 pm
Rear ones you can't, if there is excessive play they need to be replaced.
Front, I just do it by feel.
Jack wheel up, remove hub cover, remove circlip on the shaft, remove hub, unfold locking tab, undo locking nut, adjust so that there is no play but the wheel spins freely and put it all back together in the reverse order
or you can follow setting the correct bearing preload technique here
http://www.suzukiclubuk.co.uk/phpBB3/ph ... =12&t=3182" onclick="window.open(this.href);return false;
Posted: Sat Jul 23, 2011 5:01 pm
by Rjmaas512
Thanks for the info, all sorted now. Just need to find the correct brake hoses now and then I will have a car on the road. Just looking for some part numbers in my manual now.
Posted: Sat Jul 23, 2011 7:28 pm
by Newtomud
Scottiej, Thanks again... Learnt something new. (I suppose you guessed, I'm not a mechanic but I'll have a go)
Ref: Brake hoses.. I might of mentioned this before? David at Llama 4x4. :o)
Posted: Mon Jul 25, 2011 1:49 pm
Yeah Dave is highly recommended for brake hoses. Go on his web site and look at the fittings on your truck. It may be a male or female hose, depending on the model of SJ you have
Posted: Mon Jul 25, 2011 7:03 pm
by ROBBIE
1 word of warning if you phone dave at llama make sure you got a bit of time
Posted: Tue Jul 26, 2011 12:00 pm
^ haha so true! always good for a chinwag
