Quick Question,
How do you tighten the free wheeling bearings on an SJ (Spanish Module).
Looking in the manual now but thought I'd ask anyway.
Tighten Wheel Bearing
Re: Tighten Wheel Bearing
Rear ones you can't, if there is excessive play they need to be replaced.
Front, I just do it by feel.
Jack wheel up, remove hub cover, remove circlip on the shaft, remove hub, unfold locking tab, undo locking nut, adjust so that there is no play but the wheel spins freely and put it all back together in the reverse order
or you can follow setting the correct bearing preload technique here
http://www.suzukiclubuk.co.uk/phpBB3/ph ... =12&t=3182" onclick="window.open(this.href);return false;
![thumbup :thumbup:](./images/smilies/thumbsup.gif)
Thanks for the info, all sorted now. Just need to find the correct brake hoses now and then I will have a car on the road. Just looking for some part numbers in my manual now.
Scottiej, Thanks again... Learnt something new. (I suppose you guessed, I'm not a mechanic but I'll have a go)
Ref: Brake hoses.. I might of mentioned this before? David at Llama 4x4. :o)
Yeah Dave is highly recommended for brake hoses. Go on his web site and look at the fittings on your truck. It may be a male or female hose, depending on the model of SJ you have ![:) :)](./images/smilies/icon_e_smile.gif)
1 word of warning if you phone dave at llama make sure you got a bit of time ![Laughing :lol:](./images/smilies/icon_lol.gif)
^ haha so true! always good for a chinwag
