LED Lights
LED Lights
got some led rear lights on the jimny and now the indicators flash to fast. im sure ive seen a post by twiss about flasher units for leds but think it was on another forum. i asked the local motor factor and he didnt know, so im hoping some one can give me a part number thanks
Re: LED Lights
You can get those relays at lots of places. I think most are designed for when you replace both the front and back indicator bulbs though.
You can get a more expensive relay that you can mix bulb types with.
Just google "12v LED flasher unit" and you should find plenty.
Just make sure the pin layout is the same as you have now.
Re: LED Lights
Just a thought........
Why don't they just build a resistor into LED indicator bulbs so nobody needs to mess with the relay.
Edit. Been googling and can see why they don't do a built in version, the resistor needed to handle the current is quite big and would get blooming hot. Relay it is then
http://reviews.ebay.co.uk/Load-resistor ... 0010344226" onclick="window.open(this.href);return false;
Re: LED Lights
cheers darrel im askin for the son in law and at the time i just couldnt be arsed to look
Re: LED Lights
Hi Robbie, yeah that was me...
Something like this you're after then:
http://www.rawcomponents.co.uk/relays-h ... relay.html" onclick="window.open(this.href);return false;
make sure you check the pin diagram against your original relay
Re: LED Lights
cheers twiss
Re: LED Lights
no worries!!! I just click the indicator by hand when there's a police car behind me
