clutch cable
Posted: Sun May 22, 2011 10:59 pm
by Smalljeep
i put my clutch cable back on, but it was riding the clutch all the time so when i gear the anus wouldnt move, i took off the handle and cable now it jumps so that eliminates the problem as being the clutch its just the cable.
is there some way to set it up right, just seems a bit fiddly to get it right.
Re: clutch cable
Posted: Mon May 23, 2011 10:41 am
I just did the nut on the end of the cable up quite tight...
then adjusted it one way or the other at the bracket where the cable is held onto the engine...
Re: clutch cable
Posted: Mon May 23, 2011 10:44 am
by Smalljeep
is there a specific angle you put the handle on at though?
Re: clutch cable
Posted: Mon May 23, 2011 12:47 pm
http://www2.izook.com/?page_id=204" onclick="window.open(this.href);return false;
http://www.acksfaq.com/samclutchadj.htm" onclick="window.open(this.href);return false;
Re: clutch cable
Posted: Mon May 23, 2011 2:10 pm
by Smalljeep
another problem solved, got the cable on right and took the anus out on its maiden voyage.
great site you very helpful people thanks.
