Comes in three's
4eye
Comes in three's
Post by 4eye » Fri Jan 15, 2010 10:15 am
Been having a little bad luck with the sj.......first i broke the cv joint...fixed it...came to the last wheel nut and the bolt snapped clean off....took it for a test drive......perfect!
drove to work this mornin and had to leave it at a pub car park 2miles away from work due to lack of power...its just started slowly dying with low rev's....well at least that should be the end......!(for now)
my ride.........:4eye:
Re: Comes in three's
Post by ScottieJ » Fri Jan 15, 2010 11:45 am
Sounds like carb freeze to me, mine even does it sometimes with the hot air feed after a few hundred metres then once its properly wamred up its fine
4eye
Post by 4eye » Fri Jan 15, 2010 12:48 pm
Only thing is i've bed driving it in much colder temp's with no trouble.......its much warmer now! :|
srcars
Post by srcars » Fri Jan 15, 2010 7:33 pm
Is'nt carb icing mainly affected by humidity :?: I may be wrong but if it is the really cold weather would have been low in humidity where as now we are in the 'big thaw' humidity is up. Worth looking into.
4eye
Post by 4eye » Sun Jan 17, 2010 4:03 pm
Took it for a spin to see if the problem was still about......and yes it was.......so with the carb icing theory in mind i disconnected the snorkel and hooked it back up to the air box with the warm air feed......problem solved! Cheers guys 8-)
srcars
Post by srcars » Sun Jan 17, 2010 9:07 pm
8-) Glad your sorted.
