hey guys, i just bought a samurai cos i killed my last one, it has got grizzly claws on it and when im on full lock they rub the arches, i dont really want to change the tyres cos theres loads of tread on them, so im thinking of spacers, but im not a big fan of extending things beyond their design, will they put extra strain on things that cant take it and brake things prematuraly, or are they perfectly safe? and if they are safe to use, why do some cost £50 and others up to £200, whats the differance, and is there a safe width to get, cos there are loads of sizes out there. im just baffled by all the choice.
thanks
spacers
Re: spacers
Hi...i take it rub's on the inner arch...!?.......i run griz's...and also had to put spacer's on because they rubbed on the leafs......you can have the expensive billit type...or go for the cheaper cast type....i have the cast (32mm)and have never regretted taking the cheap option......you are right in sayin that it add's stress,...but its nothing to worry about....honest.......i've had mine a year and have hit them quite hard with big ruts and a few ft drops
it just depends on how deep are your pockets!....the cast 1's are very good.......so i see no harm in choosing them! But that is my own opinion taken on from a few others from this site......
i hope this helps.
chris!
i hope this helps.
chris!
my ride.........
my ride.........
Re: spacers
cheaper option it is then. thanks.
Re: spacers
also have you folded the seams over at the back of the front arches? gives you an extra inch! with a big fat hammer fold the horizontal seam down and then the vertical seam inwards and over the horizontal seam where they join and then paint.
scott
scott
