Vitara Fuel Pressure
Mphtec
Post by Mphtec » Wed Dec 13, 2023 3:09 am
Hi All, i have a 2008 Vitara 1.9ddis. The issue im having is that i have to start it with easy start and if the revs fall below1800 then the car stalls out. Initially it showed the fuel rail pressure sensor and i changed that but still the same issue. Would anyone have any ideas?
Many Thanks In Advance
Re: Vitara Fuel Pressure
Post by ScottieJ » Wed Dec 13, 2023 10:40 am
Have you tried the simple things like fitting a new fuel filter?
Could also be a faulty pump or fuel pressure regulator at a guess?
Tbh I’m not familiar with the diesel engines or later model Suzukis but that’s where I would start.
