SJ 410 Alternator Wires
border
Post by border » Tue Nov 10, 2020 11:00 pm
This is my SJ 410 Alternator wiring , bit confused as in first pic in the plug there is 3 spade connections, but the Yellow/ white is spliced in to 2 of them and the White /Red to the other. , I have another wire coming from loom with those 2 but it is not connected to anything, it is Black / White.
Should it go to that spade circled on Alt in second pic , or to one of the spades in Plug ??
Need to get myself a Voltmeter thingy.
Thanks,
border
Re: SJ 410 Alternator Wires
Post by border » Thu Nov 12, 2020 8:13 am
Battery is at 12 .7 before starting, then at 14 when idling, is this Normal. ?
Post by Anton » Sat Nov 14, 2020 7:01 pm
14.1v is the maximum charging voltage for a lead acid battery. Batteries don't operate at the voltage stated on them - that's their "nominal" voltage. They operate at a range of voltages, the "nominal" voltage is usually somewhere in the middle of the range.
I.e. Lead acid batteries operate between about 11.6v (empty) and 12.6v (full). They're unusual in that they can "float" at a higher voltage than their maximum voltage (doing that to Nicd or lithium batteries would kill them). Turn the engine off and the voltage will usually drop to around 12.6v or so. 12.7v is perfectly normal.
Everything is running as it should if you see 12.7v before starting and 14v while the alternator is charging. Lead acid batteries with high discharge capacities (such as car batteries) charge extremely slowly if you don't push them to their float voltage. It's a peculiarity of the way the electrolyte works in these batteries.
border
Post by border » Sat Nov 14, 2020 9:58 pm
Thanks Mate
DavidB
Post by DavidB » Thu Feb 18, 2021 10:23 am
My old engine had a connector with three pins, the other engine (assume it's a later type) I got had one for two.
1984 Suzuki SJ410V
