Suzuki sj 410 van tin top
A place to advertise all vehicles for sale
marve114
Post by marve114 » Tue Sep 22, 2020 8:23 pm
This sj is a 410 van
Jap build
1.6 vit lump
New timing belt , water pump ,crank seals new radiator
Rocklobster box and cradle
Samurai axles
Front axle had then swivel seals both had new oil
Rear disc conversion ( could do with a bias valve in rear brake line )
Lock right diff in back axle fulley rebuilt and back lash set with new pinion and crush coller
Rough country shocks
Spring over axle
HIGH STEER KIT
Steering damper fitted
31” trekker ( special tracks) tyres like new
New exhaust front to back
4 branch manifold ( calmini )
Defender arches
Winch bumper ( old rhino ray )
Stinger winch and ROPE and remotes
Bush cables
Snorkel
Power steering
Side steps
Seats in the back
Some spares front sammy axle 410 t box and odds and sods
Poly bushed springs ( could do with a replacement set of springs price reflects this )
Light guards all round
Pop off steering wheel horn button relocated
Shell is not the worst I’ve seen had the bulk head all welded up before last mot
Mot
Fully undersealed
Axles painted Read less
Spares included are sammy front axle complete but bent
Spare sammy rear half shafts
410 transfer box ( works just wants a seal )
Could do with a replacement set of springs as drivers side is a little flat and she leans over a touch
Orpington
£2500 ovno
Inbox me
You do not have the required permissions to view the files attached to this post.
