Baleno keyless locking
Steve698
Post by Steve698 » Sun Mar 08, 2020 10:34 pm
Hi,
Have a 2016 Baleno with keyless entry that has suddenly decided it doesn't want to lock by the the push button on the drivers side door handle. Both fobs have good batteries and work perfectly by the button on the fob. The doors all lock as they should from the passenger side button and can be made to lock on the odd occasion from the drivers side but not very often. I have found if I push the button with my thumbnail in the bottom left corner it will usually work but not always, seems the button has worn. Is it an easy job to change ? if so can someone explain how to go about it please.
