Hi,
I have a Suzuki Vitara Allgrip 2015 model. I've tried to adjust the analogue clock via the normal method of the 'joystick' controlled menu but the analogue clock won't adjust. The digital one on the dash readout has altered fine but the analogue one isn't reacting. The clock itself is still working OK other than being 5 mins or so out. (Obviously 1hr and 5 mins now)
Has anyone else had this problem please? If it needs a new clock then that's fine but I don't want to fit a new clock to find out that the problem still persists.
Thanks very much.
Dave.
Vitara Allgrip Analogue Clock Wont Alter.
- Winching along now
Re: Vitara Allgrip Analogue Clock Wont Alter.
Have you tried a 'fist thump' on the dash above the clock? maybe a loose connection?
If it's a loose connection, would I be right in presuming that the clock just prises out and the wires will come with it?
I also have this issue on my 2018 Kuro, did you find the solution please?. thanks in advance.
