Hi, I have a '91 Samurai and I need to replace the front inner and outer wings... I have found somewhere I can get them from but I thought I would just ask to see how hard it was to do? I also need to do the same to the rear inner and outer wings, again is this easy or a bit tricky?
Many thanks!
Ben
Replacing wings!
Re: Replacing wings!
Front wings are quite easy! few bolts and off they pop, but you may struggle getting the front slam pannel off!
not sure about the back tho, are they beyond welding up?
Dan
Dan
PS. welcome to the forum!
Dan
Dan
this pic may help.(bolt locations)
tony
tony
- bulkhead2_186.jpg (98.96 KiB) Viewed 5419 times
excellent pic thanks! the rears could be welded i guess... will have to go poking and see how far i need to cut back!
cheers for the help!
Ben
Ben
