SJ410 1986, full beam wire
Phillips321
Post by Phillips321 » Mon Jun 05, 2017 1:53 pm
Hi guys,
I've fitted some flood lights to the front of the truck and currently have the relay controlled by a switch that takes it's 12v from the aux for the radio. However, i wish to change this so that i can take the 12v from the full beam so they come on with them. I will keep the switch so that i can also disable the flood lights whilst on the road.
Any ideas what wire i can tap? I was hoping to bridge off a fuse but sadly the fuse is split Left and Right instead of Main and Full.
Thanks
Re: SJ410 1986, full beam wire
Post by ScottieJ » Mon Jun 05, 2017 1:57 pm
Phillips321
Post by Phillips321 » Mon Jun 05, 2017 2:29 pm
But are they negative or positive switched?
Post by turbo-tom » Mon Jun 05, 2017 2:54 pm
Phillips321 wrote:But are they negative or positive switched?
positive
Post by ScottieJ » Mon Jun 05, 2017 3:25 pm
positive
Nope his will be negative as it'll be jap built. Only Spanish ones are positive switched and I think that's only later ones.
Phillips321
Post by Phillips321 » Mon Jun 05, 2017 6:22 pm
So if it's negative switched where can i take a feed from? :-( Bloody electronics confuse me!
I'm tempted to take one off the dash light that shows full beam is on as that's near to the relay. Any idea what colour that could be? (White?)
Thanks for your help guys, it's much appreciated
Post by Darrell » Mon Jun 05, 2017 8:50 pm
Need to be wired as Scotties link (2nd post).
The relay needs a permanent positive and switched negative from the high beam.
Post by turbo-tom » Mon Jun 05, 2017 11:00 pm
Well I never lol
Post by twiss » Tue Jun 06, 2017 6:36 am
I should add that on Couriors truck we didn't bother like that, just snipped one of the high beam wires, put two connectors on and connected them to the relay.
You arent supposed to pull a lot of juice through the switch side of a relay, but the LED headlights we have hardly use much power at all.
Post by Anton » Wed Jun 07, 2017 7:57 am
I can't imagine it would hurt much to put a few amps through one, it's just an electromagnet after all. What's in there to break?
