Those spring loaded brake shoe retaining pins....
Posted: Sun Mar 12, 2017 9:45 am
by Eltoon
Re: Those spring loaded brake shoe retaining pins....
Posted: Sun Mar 12, 2017 9:58 am
by palo123
You fit rear discs instead haha
Posted: Sun Mar 12, 2017 12:19 pm
perseverance.
Posted: Sun Mar 12, 2017 1:25 pm
by Eltoon
It's perseverance wot done it. Blue-tacked the disc to the end of me pliers. I've since discovered there is a tool specially made for those buggers. Maybe I'll get one before I do the other side.......once my wounds have healed...
Posted: Sun Mar 12, 2017 2:20 pm
by ROBBIE
Hold cap with pliers, with free hand hold pin on rear of plate. Push cap in with pliers, rotate pin with other hand
Posted: Sun Mar 12, 2017 4:09 pm
by SZ5
Posted: Sun Mar 12, 2017 6:47 pm
I just use needle nose pliers. Hold the back of the pin push the cap on until you can grip the pin, then use your hand to hold disc while you spin the pin with the pliers.
Easy once you learn the technique
